Hi all...
I'll give some background. My AC was doing this thing where, no matter what speed it was set on, the force the air was blowing at would vary/be intermittent. For example, you'd be driving for a few minutes with it set on high and suddenly it's still blowing but at a very low force. Let's say I'm then driving around a bit more, hit a bump in the road and it goes back to the force it was supposed to be at. Though annoying, I didn't mind because it at least worked somewhat... then it died, completely.
I got it "repaired" a month ago but all they did was get it back to functioning "somewhat" rather than being completely dead. The varying force was still an issue. Like an idiot I thought "whatever, at least it's mostly fine now". Well, now it's back to being almost completely dead again and blowing hardly at all.
If it were you, would you suspect this as the blower itself, the resistor, both or something else? I'm trying to determine which parts/parts to save up for to try to do this myself.
If something as simple as a bump can change the force, might it just be loose wiring somewhere? If so, where?
In other words, what would you try first, second, third, etc? I'm not in a place where I can afford the cost of labor. I can barely afford the parts.
Thanks for your patience. I'm sorry for the tedious post. I know nothing of cars, mechanical terms, etc
