2009 Vibe 1.8 auto- Struts
jack101
Post by jack101 »
Just bought a 2009 1.8 Vibe with 60K according to CarFax. There is a clunk noise in the rear when going over bumps, even small ones. Don't notice any bad handling characteristics. I had this problem with a Mercury Sable and it turned out to be struts. Nothing is loose around the jack or spare that would be the source. Any suggestions. What is a good strut for replacement?
Thanks
Edit: Mine was advertised as a 1.8. Later found it was 2.4. I was suspicious on the test drive, but did not know enough about the Vibe to be sure. Love the car.
If they are nipping at your a$$ you must be out in front.
SSizler
Re: 2009 Vibe 1.8 auto- Struts
Post by SSizler »
I would recommend KYB as they are the OEM strut provider.
I have used them successfully on 2 first gen Vibes.
Monroe quick struts used to be OK, but they changed their manufacturing process recently and the new units are sub-standard IMO.
05 Base/ Lava Red/ Daughters
2 for parts
