rear door tie down?
FatherTime
rear door tie down?
Post by FatherTime »
I need to cart a couple pieces of foam board insulation from store to home. I don't see any obvious way to tie the door down safely. An ideas?
2009 Pontiac Vibe 1.8 FWD Manual Trans
SeattleJeremy
Re: rear door tie down?
Post by SeattleJeremy »
When I hauled a couch with my Vibe the guy a the store fished twine through the latch. I'm not sure how he did it, but maybe someone at the store will know.
Turo'ing 15' BMW 328i Sport - Jet Black - Auto
Daily 19' Toyota Camry SE Hybrid - Galactic Aqua Mica - eCVT
pop the hatch glass. run whatever you need through that, shut it?
SeattleJeremy
zbyers wrote: Mon Oct 04, 2021 10:57 am pop the hatch glass. run whatever you need through that, shut it?
2009 and 2010 cars cannot open the rear glass.
SeattleJeremy wrote: Mon Oct 04, 2021 3:38 pm
heh. i knew that...didn't notice OP had an 09.
depending how far you're going, you are probably fine not worrying about tying it down..just tie your cargo down.
FatherTime
I'm thinking maybe I tie a nylon rope to the rear passenger door handle, bring it up over the rear door, loop it around the windshield wiper post, then tie off the other end onto the other rear passenger door handle. How's that sound? :)
FatherTime
Well, if you ever need to tie the rear door down, my last post method worked fine. Didn't take it on the freeway, just around town. Be ready for a big dose of exhaust fumes.
