In my 06, the left bulb was burnt out so I got another one. Well, it isn't the bulb! Also, my interior lights aren't working. I checked the headlight fuses and they are fine.
What else can I check?
If you (or possibly a previous owner) ever had higher wattage bulbs in there, it might have melted the plug. Do you have a voltmeter? If so, start checking at the plug then work your way back from there. Also, interior lights and headlights are different fuses in case you didn't know. Is your radio keeping memory after you turn off the key? Because that's the same circuit as your interior lights.OrangeMamba wrote: ↑Sun Mar 28, 2021 6:40 pm In my 06, the left bulb was burnt out so I got another one. Well, it isn't the bulb! Also, my interior lights aren't working. I checked the headlight fuses and they are fine.
High beam doesn't even work.andrewclaus wrote: ↑Mon Mar 29, 2021 2:21 pm I agree with checking the socket for voltage and going from there. Does the high beam work on that side?
If you checked the fuses visually, check again with a continuity tester, or swap them side to side. Check the new bulb as well.
what about parking lights? Do you have a volt/multimeter? If not, go pick one up. You don't need a fancy one. Harbor Freight has them under $10 and Amazon has one for around $13. Just a basic one will do. Then, once you have one, start probing. Check at the plug for 12v on both high and low beams, then check continuity to ground just in case. Then, if you have nothing, pull down your steering column shroud and check for power and ground there at the headlight switch plug.OrangeMamba wrote: ↑Mon Mar 29, 2021 4:35 pmHigh beam doesn't even work.andrewclaus wrote: ↑Mon Mar 29, 2021 2:21 pm I agree with checking the socket for voltage and going from there. Does the high beam work on that side?
Cool. Thanks!SlammedNiss wrote: ↑Mon Mar 29, 2021 5:14 pmwhat about parking lights? Do you have a volt/multimeter? If not, go pick one up. You don't need a fancy one. Harbor Freight has them under $10 and Amazon has one for around $13. Just a basic one will do. Then, once you have one, start probing. Check at the plug for 12v on both high and low beams, then check continuity to ground just in case. Then, if you have nothing, pull down your steering column shroud and check for power and ground there at the headlight switch plug.OrangeMamba wrote: ↑Mon Mar 29, 2021 4:35 pmHigh beam doesn't even work.andrewclaus wrote: ↑Mon Mar 29, 2021 2:21 pm I agree with checking the socket for voltage and going from there. Does the high beam work on that side?
