So i have this problem with a 2009 vibe i just got from a family member... the battery ran dead after sitting for awhile i was started about 4 months ago and driven for a few mins and parked again... Now i replaced the battery and fuses first... now the wont start.. I jumped the starter to the battery the car will turn over... when i use the key it will not start, the starter relay is good the ignition switch is good i actually replaced thinking it might be that.. the dashboard llghts come on but the car still wont start with the key while i had the car started from the jumper wire the radio all the power door locks wont work from the key or the door i have no turn signals rear brake lights. I do have headlights though i also got the car ito gear by pressing the override under the cover near the shifter. the OBD2 scanner would not register either... Does it have a anti theft system? toyota immobilizer i have no idea if its the key or a security system.
Hopefully someone car help me out.
thanks
