Facing an annoying leak and just cleared the Chanel under the windscreen.
I noticed there was only ONE plastic drainage Chanel or plastic clip under the windscreen. The one drivers side was missing (the leak is driver side and front well) so was wondering if there was supposed to be a drainage scuttle on the drivers side?
Are there supposed to be two scuttles under the windscreen?
Plastic drain water catchers thingies? Sorry I don’t know the correct term!! Deflector? Drain scuttle?
