So, a/c blower motor stopped blowing (all speeds).
Tried replacing the resistor first, didn't fix problem.
Went to remove blower fan itself and noticed this cable was burned.
I tried cleaning some of the corrosion, plugged it back in, and it's now blowing again...
But is it safe? If not, anyone know how to replace it? Obviously if you've worked on the resistor or blower motor, not easy to reach parts. So the cable itself would be even harder to work with...anyone had to replace that cable?
Thanks for any advice.
IMG_20190103_170430_1 by Chris Hennig, on Flickr
IMG_20190103_170224 by Chris Hennig, on Flickr
IMG_20190103_170148 by Chris Hennig, on Flickr
