Ticking noise from middle of dashboard
coppens1
Post by coppens1 »
Vibe User Group 270516 Ticking noise from middle of dashboard
Dear fellow vibe Owners, today when I started my 2005 vibe, I experienced a Ticking noise from middle of my dashboard. I turned the engine off and the key position to accessories, turned off the radio, fan, air conditioning, CD player, and the noise persisted. It stopped when I completely turned the key off.
Has any one else experienced this noise? what was the cause?
BustedVibe
Re: Ticking noise from middle of dashboard
Post by BustedVibe »
Did it sound internal or external? How loud was it?
Could it be lifter tick? That's the only thing I could think of. Sometimes you can hear it even inside the car
____________________
2004 Base Automatic
kumquat
Post by kumquat »
Probably not the lifters if the engine is off.
How quickly does it tick? Is it a regular rate and rhythm?
It's clearly something electrical. Do you have an aftermarket radio?
BustedVibe
oops sorry I thought he said it only stopped when the engine was off not the key
2004 Base Automatic
Have you checked to make sure it is not the AC recirculate gear? The teeth on the gear break often and when that happens, the gear causes a clicking noise in the center of the dash. It often goes away if you press the recirc button.
viewtopic.php?f=17&t=3435&p=507341
Good luck with it
BustedVibe
This video might be relevant
https://www.youtube.com/watch?v=oUKgs6VIUY0
2004 Base Automatic
jolt
Post by jolt »
I can't hear it from here ;) but I thing trb's reply has hit the nail on the head. The stripped plastic gear will make a sound like that as the teeth jump.
coppens1
Post by coppens1 »
You all have hit the nail on the head, and even provided a youtube film showing how to fix it. It is great being a member of this group! Thanks very much. JC
