I have an 05 base model with auto trans. It has 116K miles, I bought it with 63K. When I'm on the highway the steering wheel shimmies at 65-75mph, sometimes a lot and sometimes only a little. I have put on new tires, had them rotated front to back, and balanced twice. I had all 4 wheels alignment checked. It just passed inspection and the tires seem to wear evenly. A few times I've sped up to 80-85mph and the shimmy almost disappears. Under 65 there is no shimmy at all. The brake rotors are in great shape and I have recently changed the front brake pads.
Anyone had this problem and solved it? I read through past postings and one person posting in 2010 seemed to have the same problem as me but no solution.
I don't know if there is a connection but it also seems to pull slightly to the left, which makes me wonder if the steering rack is the issue. Any thoughts, info? THANK YOU
