2009 AWD Transfer case, what is leaking (pic)
ctgottapee
Post by ctgottapee »
Can anyone take a look at their transfer case and see if they have a little leakage going on?
It looks like I'm leaking a bit around the seal, although checking the fill plug and it sees to full to where it should be.
I wonder how much on average is there leakage around the shaft seal, which is what looks like to be the source in the pic
gtv237
Re: 2009 AWD Transfer case, what is leaking (pic)
Post by gtv237 »
Looks to me like the axle seal is leaking.
GOF
Post by GOF »
Yeah, What he said.
New seal and check for bearing play.
ctgottapee
There is obviously some leakage, but is 'some' normal?
I don't know the last time this was cleaned up, and checking the fill level, it was good
