I have a FWD and they made sure to double check to make sure they have the right oneehoff121 wrote:Silly question, but do you have a FWD or AWD?
They have different canisters, so if there was a mix up there, you might expect some issues.
I might be missing something but I see nothing in this link that could even be slightly helpful to me. Thanks thoughvibrologist wrote:Seems you are not the first one experiencing this problem. This thread may be long but it sure has some hints and pointers:
viewtopic.php?t=23221" onclick="window.open(this.href);return false;
You already replaced the canister with out success. That means most likely the canister you replaced was fine. In the related thread a guy opined that multiple EVAP Codes are likely caused by one defect. Most likely a valve is stuck open or closed.mpgaller wrote:I might be missing something but I see nothing in this link that could even be slightly helpful to me. Thanks thoughvibrologist wrote:Seems you are not the first one experiencing this problem. This thread may be long but it sure has some hints and pointers:
With that in mind I would make a leak test and or inspect and clean the individual parts that make up the whole system.The evap system consists of a vent valve ( as fuel is removed from the tank the pcm opens the vent valve to replace the fuel that is removed to keep the tank from imploding)
A purge valve ( this valve opens to the charcoal canister to expel excess pressure so the tank does not expand and burst)
A pressure sensor ( the sensor mounts on top of the tank and reports pressure to the PCM)
The purge valve vents to the intake so that fuel vapors are burned
The system is a low pressure system, never more than 1 psi. More than likely you have a vent valve stuck open. Vent valves suck in outside air and over time suck in dirt/dust which causes them to stick. A bad purge valve generally sets a code specific to the purge valve. If you put 7-8 psi on the evap system you will likely cause a leak.
For anyone reading this later on and wondering about the relevance, never top off your tank after it cuts off because you can damage the EVAP system like that.ehoff121 wrote:http://www.yarisworld.com/forums/archiv ... 25989.html
Interesting thread on yaris world with posts from '05 Corolla owners. Do you tend to top off the tank at fill up after the pump stops?
My '05 AWD had different codes with the EVAP system that turned out to be a leak in the corrugated plastic hose.
