'09 1.8L Wilwood 4 piston brake upgrade
dragon64
Post by dragon64 »
A friend gave me a used Wilwood brake kit for a Cavailier that was used on a show car years ago. Amazing how close of a fit it is on my '09 Vibe. The hats had to be faced "0.040 on the bolt face. Fortunately I have some scrap 7075 Aluminum kicking around the shop. because I had to mill new caliper mounting bracket for the Vibes front spindles . Went with Hawk HPS pads for a little extra bite. Matt gunmetal painted calipers and the 12.2" rotors fit under my 16" wheels for a pretty stealth look.
2009 Vibe 1.8L Manual - DBW controller, Hydraulic engine damper, S/S brakeline retrokit,22mm solid Rear ARB, urethane rear coil dampers, Front strut bar with brake cylinder brace, PIAA 410 driving lights, PRM Intake Wilwood front brakes, Lexus hood lifts
Re: '09 1.8L Wilwood 4 piston brake upgrade
Pictures?
I'd also be interested in hearing some more information and seeing some pictures of the "Lexus hood lifts" listed in your signature...
dragon64
Post by dragon64 »
The used LS400 hood lift failed on my so designed my own kit using one off the shelf Stabilus gas spring and brackets instead of the 2 from the Lexus.
vibenvy wrote:Pictures?
X2. Pictures ...... or id didn't happen :o
2014 Silverado, 2004 Vibe GT
dragon64
Post by dragon64 »
One caliper sprung a leak. Just found out that calipers have larger 1.75" bore pistons not 1.5" pistons the original kit should have had. Now have to more parts and return others. Was kind of wondering why I seem to have so much additional braking force over OE brakes.
