no power
09Viberator
no power
Post by 09Viberator »
our 2009 pontiac vibe has lost power going up hills and i have to downshift to 2nd gear to get power.... it has the 1.8 with about 35,000 miles plus we use 89 octane Arco gas
on another note, should i schedule for a tune up at the dealer? needs plugs, wires and cap, radiator flushed, and needs a new air filter as all of those are what we drove off the dealership lot with...
Re: no power
Plugs are fine for another 65000 miles. You don't have a distributor or spark plug wires.
Antifreeze should be changed now as it's been 5 years. Air filter and cabin air filter are easy diy items that take 5 minutes. Maybe fun a small bottle of fuel injector cleaner through your next tank of gas.
Is your check engine light on?
Zimm
Re: no power
Post by Zimm »
cleaning the MAF seems like a good place to start.
Salsa Guy
Re: no power
Post by Salsa Guy »
I don't suggest cleaning the MAF. They are very tender devices and if not done right it will cost you $100 or more to replace it, just inspect it for any chunks of crap. Make sure you have the battery disconnected when fooling with it. Very rarely will cleaning the MAF do anything to improve the performance.
I assume the Check Engine Light isn't on. If not you may want to take it a parts store and have them read it for you anyway. Sometime the CEL light doesn't work. You may need to run some fuel system cleaner through it also.
Nasmfell
Re: no power
Post by Nasmfell »
Have you had the hidden PCV valve and hose checked?
09Viberator
Re: no power
ok ya... does need to get the radiator flushed but that's easy to change i guess..... I will run some fuel injector cleaner on it's next gas up and will see how it runs, because as of now, in drive, the car needs the gas pedel down about half way to get any real power
09Viberator
Re: no power
Nasmfell wrote:Have you had the hidden PCV valve and hose checked?
no, I have not!
09Viberator
Re: no power
Salsa Guy wrote:I don't suggest cleaning the MAF. They are very tender devices and if not done right it will cost you $100 or more to replace it, just inspect it for any chunks of (removed). Make sure you have the battery disconnected when fooling with it. Very rarely will cleaning the MAF do anything to improve the performance.
no light, just the Tire pressure monitor light when we have the snow tires on.
