How many minutes off is your clock ?
808 Vibes
Post by 808 Vibes »
Mine (the Monsoon 6 CD option) was off by 5 or 6 minutes, I set it correctly, and it's still off. :x Note to self: the next time I bother to set it to the "correct" time, I should set it for two minutes ahead. :lol:
~ ALIS VOLAT PROPRIIS ~
Re: How many minutes off is your clock ?
My bathroom clock is fast by who knows how many minutes. My car clock isn't even used. I wear a watch I synced to my school clocks, but my Vibe clock should be dead-on. That's a weird thing with the factory Vibe radio, though. Even if you set the time right, it'll be off within a week. It's happened a few times back when I had my OE radio.
jake75
Post by jake75 »
The clock in my '09 Vibe gains time. Maybe a minute or so per month.
ehoff121
Post by ehoff121 »
I use the radio signal update feature and find that it is usually pretty accurate between updates.
The 2005 Moon & Tunes single CD unit allows you to use an FM radio station that is broadcasting time info (i.e., radio display shows "INFO" lit) to update the clock by pressing and holding the HR & MN buttons at the same time.
MrHatchWagon
Post by MrHatchWagon »
My Kenwood reads 60 minutes late, because I forgot how to set the clock when we sprang forward for spring.
* Voted May 2012 MOTM! *
How To: Cupholder LED Mod
09vGT
Post by 09vGT »
Mine keeps time almost perfectly. Maybe falling behind close to or one minute in a six month time period.
crazytrain
Post by crazytrain »
09vGT wrote:Mine keeps time almost perfectly. Maybe falling behind close to or one minute in a six month time period.
Similar here, but might be closer to 4-5 months. Stock radio w/ CD player.
2006 Stealth Vibe <-- Current
2010 Subaru Forester <-- Wife's Current
I miss my 1992 Saturn SC2 - drove it for 12 years
It works... may be off a minute or two either way. Don't know for sure as I haven't compared it to anything other then the clock at work.
PearHunter
Post by PearHunter »
By the time it's time to change the clocks, I'm off by a good 10 minutes. Never fails.
jake75
Post by jake75 »
PearHunter wrote:By the time it's time to change the clocks, I'm off by a good 10 minutes. Never fails.
Ahead or behind?
