Part # for the small, rectangular plate next to the driver-side coin holder?
Psychobroker
Post by Psychobroker »
Does anyone know the GM part # for the small, blank insert/plate adjacent to the driver side coin holder and security light? I am almost done with my sub install, but need to order a few blank plates for the amp on/off switch, and just in case I screw up lol. I've already used the one provided for the bass control knob. Thanks in advance!
NSimkins
Global Moderator
Re: Part # for the small, rectangular plate next to the driver-side coin holder? (Psychobroker)
Post by NSimkins »
From: http://forums.genvibe.com/zero...71278Quote, originally posted by ragingfish »Got the part in today! Turns out it's the right one! So, if you're looking for extra blank plates for the left of the steering wheel, or to replace the little coin slots under the e-brake, the part you need is:88970565 COVER $2.75
Psychobroker
Re: Part # for the small, rectangular plate next to the driver-side coin holder? (NSimkins)
Sorry about that...I didn't even know how to word my search for that part lol . Thanks Nick!
NSimkins
Global Moderator
Post by NSimkins »
Quote, originally posted by Psychobroker »Sorry about that...I didn't even know how to word my search for that part lol . Thanks Nick!No need to apologize - it took me a bit to find it but I did remember seeing that part number from the past.
ragingfish
Post by ragingfish »
Don't forget the same plate can replace the pesky coin holder under the e-brake as well!
2009 PONTIAC G8
Psychobroker
Re: Part # for the small, rectangular plate next to the driver-side coin holder? (ragingfish)
Yep, thanks for the reminder. That might be used for red under-dash LED's, if I decide to go that route
ullbergm
Post by ullbergm »
i put my garage door opener down there.the momentary push button came from radioshack.
Car: Two-tone Base Abyss, Moons and tunes, Power packageMods: 20% tint, Reflective Black GrafxWerks Overlays, German Hella Horns, Hardwired Valentine One, red interior dome lights, custom cargo floormat, police scanner, ham radio, cellphone kit and a bunch of antennas on topWishlist: Rubber floormats, million dollars
ragingfish
Re: Part # for the small, rectangular plate next to the driver-side coin holder? (ullbergm)
That's pretty cool!What did you do, disassemble the transmitter and tap into it?
2009 PONTIAC G8
ullbergm
Post by ullbergm »
Quote, originally posted by ragingfish »That's pretty cool!What did you do, disassemble the transmitter and tap into it?Yep, it's really easy. All i did was open it up and solder two wires to the leads from the push button and then run them to the button by the coin holder.I like it, looks nice and clean.
ragingfish
Where's the transmitter? Just floating around back there?
2009 PONTIAC G8
ullbergm
Post by ullbergm »
I made the wires from the button to the opener about a foot long and then i attached the opener to some of the wiring behind the panel with some ziplocks to keep it from moving around.It was kind of a pain to lie on my back and try to ziplock it in place, but now it doesnt rattle or move around.
drummerdude
Post by drummerdude »
Talk about a pain in the (removed) when the openers battery goes dead!
2006 MazdaSpeed6 GT which is for sale if anyone is interested...
AKLGT
Post by AKLGT »
i've got my heated seat button where the useless coin holder is. the security one is next to it and the last blank is being reserved for my independant foglight switch once i have more time and space to figure that out. plus, my unichip switches will probably go in the compartment where they are just shoved in currently, but will most likely mount them permanantly in there so it looks custom.
AKLGT1998 Subaru 2.5RS
VibeFever
Re: Part # for the small, rectangular plate next to the driver-side coin holder? (trdvibe)
Post by VibeFever »
Yeah I just recently installed an aux input adaptor, and ran the stereo cables under the carpet to the useless coin holder below the e-brake. I mounted a jack there in one of the blank panels from the dash. I have a short pigtail which now plugs between my mp3 player and the jack.
