Hello all, I'd like to get some advice on any maintenance I should take care of before taking a 600 mile trip from rural Ohio to rural New York in my 2003 fwd automatic with 214000 miles on it. Also, I'll be there for 6 months so, anything I should be aware of as far as up keep that New Your requires that an Ohioan would have no knowledge of. (Is that too odd a question?) Mileage is primarily highway but more recently has been building city. I bought the car a year and a half ago with 172000 and have done a drain and fill on the transmission and replaced the pan gasket and filter about 30k ago and within the last month have done a simple drain and fill. I replaced the plugs at about 174 and feel safe that they are ok with 40k on them. So, aside from that, possibly tires, brakes and oil, is there anything I should think about before taking my car on a 600 mile straight run, across the Allegheny plateau and then make that trip back in October. I know I sound a bit helpless and overly worried but I appreciate the help.
While you're checking the oil, I assume you'll be checking your other fluids? Also, remember to check your spare while you're checking the other tires.
Quote, originally posted by MrHatchWagon »While you're checking the oil, I assume you'll be checking your other fluids? Also, remember to check the air pressure in your spare while you're checking the other tires.Sometimes word just get lost.
2008
47,891 Added new horns
47,900 Yokohama Avid 205/55-16 $492.40 drive out w/TPMS rebuild kits
69,036 Added sound deadening
70,395 Battery
106,019 Yokohama YK580 205/55-16 $589.19 drive out
