This is a quandary. I have not come to a firm conclusion myself. I sometimes think it would be smart to use either the specs from Ford or Chrysler on new long life coolants because of availability and price. This is after a thorough flush, and maybe another flush after a short period of time to make sure. The other option is to pay the few extra dollars and put the Toyota long life in. It does not amount to that much over a 3-5 year period. If you insist on changing every two years anyway, because whether long life or not, certain things break down fairly quickly, then maybe a very low silicate coolant that is closer to the traditional stuff. Silicate supposedly causes more wear on water pumps, seals and other things nowadays, but that seems iffy to me too.What I can remember is that there is, or was, a chemical in the GM dex-cool (2-ethylhexanoic acid {2-EHA}), that is not really a good thing, whereas some of the other manufacturers dex-cool does not have it and is safer, especially with an accidental mixing of antifreezes.I will have to look for some of this info and will edit on this post if I find it.The controversy with dex-cool is a touchy subject anyway and they have revised the formula and changed manufacturers over the years. Another possible conflict with dex-cool is if there is a leak in the system, if it get low, or lots of oxygen is mixed with it , it breaks down quicker and can cause bad things, like more chemical reactions to various metals and "sludge" or gelling, if I remember right.I just do not know at this point, sorry. PS: If the Toyota super long life pink coolant is premixed 50/50 with distilled water (which I do not know for sure), how do you account for the water or coolant left over in a flush to get a proper ratio mix?
http://www.artsautomotive.com/...luids neat site with pictures of oem specific fluids, sealers, etc. for Asian vehicles. http://www.globalautoparts.biz....htmlhttp://www.paulstravelpictures...Guide/,, This might of answered my own question. If you already have long life pink in, do not flush, just drain and fill with Toyota SLLC or Zerex Asian Vehicle coolant per Toyota's recommendations. The search continues...http://www.popularmechanics.co...72246http://www.bobistheoilguy.com/...99442http://sancarlosradiator.com/a...t.htm antifreeze: Coolant Chemistry And Corrosion..."Dex-cool uses 2-EHA which among other things is a plasticizer which has the effect of softening plastic. GM intake manifolds are made of plastic..."...EDIT: My thoughts after researching antifreeze/coolant more fully:
http://forums.genvibe.com/zerothread?id=44821
2010 Vibe 1.8 auto, fwd, base, air, preferred package, cargo mgt, cargo cover, ultra white.
