Quote, originally posted by Crabbycrab »Would you describe your experience with the differences between the two in terms of:noisewind passage into the interior with windows down or crackedrain Removing the sticky tape was a nightmare for me, how did it go for you?Merci!I've spent a few kms on the highway for the same questions this afternoon I'd say there's a bit less wind noise BUT as the window is sightly open and loose in the weathestrip, on bumpy roads I can hear it shaking and bumping the visor which is a bit annoying.Heavy rain and thunderstorms forecast tomorrow here so I'll check for aerodynamics  I don't if it was your case, but my old visor tended to swirl the water on my front windows making them dirtier.As for the old tape, I used a plastic scraper (badge remover) and WD40 as a solvent, finished the job with an old rag and elbow grease. I'd say it took about 90 minutes to clean it off. Had to wash the car thoroughly after, there was oil everywhere!FYI, I ordered from
http://www.weathertech.ca/ and got it next day to my door. I wanted to order from the US .com site since it's 40$ cheaper + the current exchange rate, but it's impossible.I'll post updates on my experience this week!
