Fog & Head Lights Replacement
digitalskull
Post by digitalskull »
Good Morning,I want to change my lights & put these in... (see ebay links below)I was wondering if they would cause any problem regarding power consumption or having too much Wattage on them.Fog lights specs on the ones I want to buy:Super White Light5900K Low Input High PowerHallogen bulb 900612V 100WHead Lights specs on the ones I want to buy:Plasma Xenon White Bulb 90037000K80W-100W of brightnessHead Lights: http://cgi.ebay.com/ebaymotors...:1123Fog Lights: http://cgi.ebay.com/ebaymotors...83bbcThank You for your help!Dan
Wolfman213
Post by Wolfman213 »
The headlights should be ok bc the 80-100w is most likely measuring with the brights turned on. You may want to double check with the seller. I'm not sure how much our stock headlights run with the brights flipped since I run projectors.The fogs are probably not a good idea since they are listed at 100w. They will most likely fry your wiring harness.
digitalskull
How much Wattage are our stock fog lights?
Wolfman213
55 IIRC
Re: (digitalskull)
Welcome to GenVibe!!! I have something similar to those in mine, 80W... Got them at Princess auto, paid around $7 (as far as I can remember) last year. I've had them on for over 12 hours before with only a break for fuel... everything still works great, no melting, no problems!!! I don't have fog lights so I can't speak for those.
