poor man's supercharger thermal gasket insulated spacer
Supercharger, turbo, nitrous, and anything that has to do with forced induction
sikvibe
Post by sikvibe »
I used my old plastic intake to make a nice little spacer between the s/c and the engine block..I was looking for a thermal gasket such as the one that hondata sells, but they only make it for the 2zz..So after hacking it off with a saw, It cost me $20 bucks to get it machined down to .5 inch at a buddies machine shop.http://www.flickr.com/photos/4...31442/
*03 SIKVIBE*Performance mods in order:18x8 Konig illusion rims w/ falken ziex 235/40R18 tires~1.5" lowered TEIN S. tech springs~GM performance parts supercharger~TRD add-on ECU for S/C~Drop in spectre high flow air filter~Tripod center dash oil pres.,egt/boost, a/f guage pod~Homemade .5" custom S/C thermal intake spacer~1.9" aluminum S/C pulley~150 psi>530cc nozzle water/alcohol injection system~2.5" single cat proflow muffler opposite exit install
keithvibe
Re: poor man's supercharger thermal gasket insulated spacer (sikvibe)
Post by keithvibe »
I wonder if this can be used as a spacer to mount the 2zz intake to the 1zz engine... mmmm
sikvibe
Re: poor man's supercharger thermal gasket insulated spacer (keithvibe)
Post by sikvibe »
Your mechanical knowledge or lack thereof, is really depressing keefer..save your 2 cents for the peanut gallery, just so you know when some one does something new and inovative it's sick and when some body messes up we'll call it a keefer...
keithvibe
Post by keithvibe »
HAHA you actually made me laugh, shows to go just how much YOU knowthis is the member JIN602_05 on newcelicawhats that? 2zz intake on a 1zz engine.But, your right I don't know anything
northvibe
Post by northvibe »
Quote, originally posted by sikvibe »Your mechanical knowledge or lack thereof, is really depressing keefer..save your 2 cents for the peanut gallery, just so you know when some one does something new and inovative it's sick and when some body messes up we'll call it a keefer...how was his reply bad or insulting? The 2zz IM flows a lot better than the 1zz and its metal so with a nitrous injector it wont explode with the puddling issue the 1zz has.
BlueCrush
Post by BlueCrush »
Quote, originally posted by keithvibe »I wonder if this can be used as a spacer to mount the 2zz intake to the 1zz engine... mmmmThat's a really good question, keith. That just might work.Quote, originally posted by sikvibe »Your mechanical knowledge or lack thereof, is really depressing keefer..save your 2 cents for the peanut gallery, just so you know when some one does something new and inovative it's sick and when some body messes up we'll call it a keefer...Mike, you need to chill and show some respect. Keith knows more about your engine and your Vibe than you do. When someone keeps replying like you are we call it a BAN...
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
ou.grizzly
Post by ou.grizzly »
Quote, originally posted by sikvibe »Your mechanical knowledge or lack thereof, is really depressing keefer..save your 2 cents for the peanut gallery, just so you know when some one does something new and inovative it's sick and when some body messes up we'll call it a keefer...Say's the member who wants to convert his FWD to AWD and asks me IF I am sure it cannot be done when I clearly state the floor pan has a different stamping.*rolls eyes*
lovemyraffe
Re: poor man's supercharger thermal gasket insulated spacer (ou.grizzly)
Post by lovemyraffe »
Quote, originally posted by BlueCrush »Mike, you need to chill and show some respect. Keith knows more about your engine and your Vibe than you do. When someone keeps replying like you are we call it a BAN...+1Keith is one of the most knowledgeable members here. He has been a great asset to these forums. I know he has helped me out several times. His knowledge of this car still amazes me.
keithvibe
Post by keithvibe »
I honestly like what you did. You gave me and others ideas. Which is why I posted my question above.I never claimed to be a master mechanic, nor the know it all you seem to think I am. I'll be the first to admit I was wrong.
keithvibe
Post by keithvibe »
see... your info, I passed along... and lookhttp://matrixowners.com/index....rt=60
sikvibe
Post by sikvibe »
Oh, my bad keith's quote "I like your spacer for the Supercharger LOL" you can find it over in the 2.5" flo pro install..I see how I could have miss taken that...
