headlights coming on in cold weather
waynek
Post by waynek »
In real cold weather(below 10degrees) the headlights on my 2003 vibe are turning on by themselves. The car is parked, engine off, and parking brake is engaged. Has anyone had this happen? How do I fix it?
Re: headlights coming on in cold weather (waynek)
THis is something that first showed up in 03 Matrix owners, and some vibers have had it as well. I believe the solution is to replace the headlight switch on the steering column, and a workaround is to push the turn signal lever into high beam mode when you turn the car off. The auto headlights will go off when you turn off the car, but being in high beam mode seems to prevent the hedlights from coming on by them selves. There are some threads here about this, somewhere. edit - one is http://forums.genvibe.com/zerothread?id=2686 I know there are others.Welcome to genvibe
waynek
Re: headlights coming on in cold weather (joatmon)
Post by waynek »
thanks I'll try that
