My CEL has been going on and off for the past week or so. It only seems to come on after I've parked it outside for a while. Occasional rough idle. Not sure I want to replace the oxygen sensor if that is not the problem. Thoughts?
http://www.obd-codes.com/p0171It could be a vacuum leak or dirty MAF sensor. I would check all your hoses first and clean your MAF sensor before replacing the 02 sensor.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Run a tank or two of Techron injector cleaner. Not STP, not Goldbloom and Finch, Techron only. In my 5 + years of Vibe ownership the injectors seem to be easily fouled and that code comes up on occassion. Now I just run a tank of Techron at each oil change.
Well I spoke too soon. The light is back. I guess I'll try cleaning the MAF sensor again and then run some Techron, although in the past that stuff hasn't helped me any.
If the light comes back, try checking for a vacuum leak, seeing how you can only clean the MAF sensor so much before it actually does get clean. Or you could easily go to a dealer and have them diagnose it for you if you feel a bit nervous about the code.
2003 Vibe Base - Sold2005 Corolla LE 5 speedcustom short ram air box6k HID kitIn memoriam of the Vibe, may you rest in peace:http://www.cardomain.com/ride/3168634
If CEL (P0171) comes on during subfreezing temps and accompanied by rough idle, problem could be leaking intake manifold gasket. Dealer should cover repairs under TSB...http://toyota.justanswer.com/u...1.pdf
He'd better hope his car has less than 36,000 miles, otherwise they won't cover it....and an intake manifold gasket isnt bad...if it was the intake manifold itself then that would be something I'd wanna take care of immediately.
