hu problem
burgmovibe
hu problem
Post by burgmovibe »
I recently installed a blaupunkt san deigo mp27 in my vibe and there seems to be a hissing almost static sound coming from the speakers, I've spoken to crutchfield and blaupunkt and they both say it is due to the factory amplifer. Has anyone else had this problem and if you did how did you fix it.
Sublimewind
Re: hu problem (burgmovibe)
Post by Sublimewind »
Quote, originally posted by burgmovibe »I recently installed a blaupunkt san deigo mp27 in my vibe and there seems to be a hissing almost static sound coming from the speakers, I've spoken to crutchfield and blaupunkt and they both say it is due to the factory amplifer. Has anyone else had this problem and if you did how did you fix it.It's very likely the amp is the problem... how is the HU integrated into the factory amp?? Which harness or LOC (line output converter) did you use? It's not cut-and-dry simple when working through a factory amp..
burgmovibe
Re: hu problem (Sublimewind)
its all connected with with a wiring harness that crutchfield sent theres no converter involved.
Sublimewind
So you have the factory amped system then? M&T or the other one? If so, they likely sold you the wrong harness.. I haven't done an install with a factory amped system, but others here have, do some searching and/or wait for the others to chime in...
burgmovibe
Re: (Sublimewind)
I finally went ahead and installed a pac oem2 adapter and it worked perfect, no more sound. It was a pretty simple fix.
Kevzaz
Post by Kevzaz »
Can you explain how it works and how you did it?I have the same problem. Pisses me the hell off sometimes.
burgmovibe
Re: (Kevzaz)
basically it lets you adjust the gain of each each speaker. All you need to do is wire it between your aftermarket head unit and your wiring harnness. When you wire it all up and get it connected to the car make sure all the gain controls are all the way down. Next turn your radio up half way, after you do that start adjusting each gain control, the all need to be the same I believe once you get it the way you want it put it all back and your done. And by the way the only place I have been able to find these is at crutchfield website and ebay, good luck I know it frustrating.
Kevzaz
Post by Kevzaz »
It has 4 Channels. But I got 7 speakers. Does it still work?
Sublimewind
Re: (Kevzaz)
Quote, originally posted by Kevzaz »It has 4 Channels. But I got 7 speakers. Does it still work?You may have 7 speakers, but you only have 4 outputs from the radio.. Which gets split in the front to mids/tweets... mids only in the rear and the sub.. ='ing 7 speakers..
Sublimewind
Re: (burgmovibe)
Quote, originally posted by burgmovibe »I finally went ahead and installed a pac oem2 adapter and it worked perfect, no more sound. It was a pretty simple fix.THAT'S what I was thinking of... good show mang..
burgmovibe
Re: (Sublimewind)
exatly what he said except I only have 6 speakers.
