Ok what is the difference between the GT Gage cluster, and the base, and is there a dif in the AWD too. I know the RPM's, and the Speedo are dif, but what about the bells and whistles are they the same?
The Base and AWD Gauges are the same. The GT Cluster has a higher Red line. Can't remember if the speedo is the same. The bells and whistles are the same (at least the plugs are), but I'm not sure if a GT cluster will work with a Base/AWD ecu.
