Timing belt????
crashandburn
Timing belt????
Post by crashandburn »
A quick question before I go to a dealer amd get hooked....I assume both the Vibe engines have timing belts, what is the change mileage and cost?The 08 & 09s have the 100,000 mile powertrain warr. I was just wondering if the change mileage was inside this window?
Re: Timing belt???? (crashandburn)
Not to worry, you've got a timing chain all '03-08 models. I'm assuming the 09's also have chains, but I haven't heard either way. I don't see them going back to a belt quite frankly, so I bet they still have chains in them too.You'll only have to replace the chain if there happens to be a problem with it, which is very rare at best.
crashandburn
Re: Timing belt???? (ColonelPanic)
Thanks...I hate belts, I had one break on a Eagle Talon turbo with only 19000 miles, was repaired under warrenty but the engine never had the same feel after that.
joshman
Post by joshman »
Great to hear this! My wife was asking about whether it had a belt or chain...Sounds like its more reliable.. doesnt need changing as often as a belt?
stealth
Re: Timing belt???? (joshman)
Post by stealth »
The Vibe has a timing chain which generally requires no maintenance and doesn't need to be changed. My last vehicle had a timing chain & ran well for 15 yrs without any problem.
kevera
Re: Timing belt???? (stealth)
Post by kevera »
The Vibe does have a chain,but chains do stretch.Most do need to be changed at the 250-300 k mark.Looks like you have a long way to go before you have to worry about that.
