Sticky Throttle
antoniazzi
Sticky Throttle
Post by antoniazzi »
Hello - Love this site! I have found that when I release the accelerator abruptly, the pedal then sticks when I go to press on it again. If I release gently on the accelerator, it does not stick when I press on it again. Anyone else experience this? And if so, any solutions? The problem is definitely not with the pedal or cable. I have tried spraying WD-40 on the spring of the throttle, but that made no difference.Thanks! JM '05 GT
coldmm803
Post by coldmm803 »
welcome to the board, i've not experienced this. i see you have a gt, mines a base 05 which doesnt have a cable its drive by wire aka electronicly controlled
Petrucci914
Re: (coldmm803)
Post by Petrucci914 »
Hmm, an 05. Is that Drive by wire or not? If you have a regular throttle body then my guess is that it is gummed up. That'll cause the throttle to stick. take your intake off the throttle body and look at the butterfly valve........see if it's gummed up.
2003 Pontiac Vibe Base - AutomaticTRD Supercharger w/ Smoothflow PulleyaFe Drop-in Filter - DC Sports HeaderFull 2.25" Exhaust -Magnaflow Catback + CatsOptima RedTop - Tru-Cool Tranny Cooler
zionzr2
Post by zionzr2 »
would it be possible for a air pressure differintal to be the cause of the stickyness??
northvibe
Re: (Petrucci914)
Post by northvibe »
Quote, originally posted by Petrucci914 »Hmm, an 05. Is that Drive by wire or not? If you have a regular throttle body then my guess is that it is gummed up. That'll cause the throttle to stick. take your intake off the throttle body and look at the butterfly valve........see if it's gummed up.All GT's are drive by cable... so yeah try using your hand on the TB rotor to see if you can get it to stick there, otherwise maybe the cable is catching on something between the pedal and the TB rotor.....
BobofTheVibe
Re: Sticky Throttle (antoniazzi)
Post by BobofTheVibe »
The fact that the speed at which you release it makes me think (not know) that the cable may be getting caught up somewhere - like northvibe said. I would clean the throttle body first anyway since its easy, somewhat quick and would eliminate the possibility of a sticky gummy throttle.
- Ann -2003 Pontiac Vibe: Lava Two-Tone Mileage as of 10/15/07: 88,095Modifications: 2/3 on my floor, 1/3 on the car.
Petrucci914
Re: Sticky Throttle (BobofTheVibe)
It's not cable. It's DBW.
northvibe
Re: Sticky Throttle (Petrucci914)
Post by northvibe »
Quote, originally posted by Petrucci914 »It's not cable. It's DBW.he said 05 GT...gt models were cable, only the base/awd went to dbw.
Petrucci914
Re: Sticky Throttle (northvibe)
oh ya, duh. I looked at the post too quickly and thought it was another post I was posting on. Damn scatter-brain.
northvibe
Post by northvibe »
we better SC your brain with some NOS energy drink! hhahah
antoniazzi
Thanks for all your replies! The GT has a accelerator cable, and the cable is not the issue because when I move the throttle body by hand (with the engine on or off) the throttle body itself gets stuck after I release it abruptly. Any other ideas besides some kind of blockage inside the TB? Thanks, JM
northvibe
Post by northvibe »
even moving it by hand since it is a cable...could be the cable, you are pulling on the cable when you move the black rotor. Although...it could be the butter fly that is sticking...you would have to take the TB off to see exactly which one it is.....
BobofTheVibe
Re: (northvibe)
Northvibe is quite correct. I would go ahead and just remove the TB assembly, pull the cable, if it sticks, its the cable, if not give the throttle body a real nice cleaning. Do you use an oiled air filter maybe? Maybe, not most likely, the oil could come off of that and get in the throttle body.
