OK, I'm going to try to reply to all these posts since my last visit, so here it goes...Quote, originally posted by kevera »Dude,don't be stressed.There is a guy on 9th gen selling an ECU for the auto,maybe talk to him.Or tell them to ship it to Toyota,maybe they will be able to get an ECU easier.Here is the install manual,it will have the hook-ups for the ECU.
http://paceperformance.com/pac...7.pdfThanks for the info Kev! Not sure the pdf will help or not, I think at this point they need the OEM ECU pinout to figure out this brown wire that is hanging. They called me today and I guess at this point they have it narrowed down to 2 pins, but they aren't sure where it goes, and called me to call Andre (draday55) to find out what they wire was and where it went since he installed it.Quote, originally posted by keithvibe »I bet someone cut something that wasn't ment to be cut and sent a surge threw the system and fried your ecu... you did say the HU was out of the car when they were working on it, and the new one wasn't installed yet... question is why were they trying to start the car in the middle of the install...I bet they didn't disconnect the negative battery cable and in not doing that did some major damage to your ecu when they cut a wire. Then they just called you to cover their (removed) from a lawsuit to make it look like you did something wrong... the car drove in there perfectly fine... i would be screamming WTH did you cut to fry my ECU? I drove the car in here, one of your employees did something they weren't ment to do and damaged my car now how are you going to fix the problem?This is my guess. He said he was trying to get a signal off a wire in the ECU harness for the navigation part of the new HU. The - terminal was NOT off of the battery, whether it was at any time, who knows, maybe they put it on when they tried to start it, maybe they never took it off. I said the same thing you did, it drove in, it will drive out, and with no $ from my pocket! They ****ed it up, they will be fixing it! Quote, originally posted by chevelle_lover »Check out TRD. I think they are selling the superchargers separate from the install kits.I'll look into it if the need arises, but they will probably be having to deal with that themselves, they broke it, why should I have to go through any trouble to fix it!Quote, originally posted by WaveAction »i dont get why they were installing the stock ecm..i know in my sunfire all i did was hook the new HU up..and me i'd sue them for being stupidAs I stated above, they were taking a speed signal or something of that nature for the navigation/GPS.Quote, originally posted by ajflan »That really sucks to hear, sorry you're having so much trouble.Indeed! Quote, originally posted by Sublimewind »EDITED:And this is exactly WHY i install all my own gear... I info is out there, there is ZERO reasons why you couldn't do it yourself... I'm not trying to blast you man... It's just that i've found that 80% of the dumbazzes in install shops don't know their (removed) from a hole in the ground... EDIT below:This situation is EXACTLY why i became the car guy that i am today... I had a MKII VW GTi that was a pile of JUNK, bought it NEW that way... It HAD to be the last MKII to come off the line the day after cinco de miao(SP?) It was a TOTAL hunk of garbage... By the time i sold it, i could have bought it again with all the repair work that had gone into it..... I VOWED from that point on that i was going to LEARN everything i possibly could about the repairs that i had soooooo much trouble with over the time i owned that VW... In this day if the interwebpornonet, there is almost ZERO reason not to do your own repairs/installs... I'm sorry, but, this situation makes me soooo personally MAD, not at you man, but, at the complete TARD that worked on your car.... I would have made that punk keep the store open TILL IT WAS FIXED.... They surly had internet access, there is NO reason you should have driven out of there... Oh, I hear ya! I've done most of the work myself, but I figured there was LESS likely of a chance of something getting screwed up if I took it to "trained professionals" with lots of experience to get it done. Looks like I was wrong there! They do have I-net access, and he was trying to find the diagrams, but he said all the info he was finding was on forums and what not that require you to have an account (probably MO! lol) and I guess that was too much trouble for them. He claims he couldn't find the info he needed on the web. And as for driving it out of there, it is still in their shop! They knew they couldn't let me drive it out of there in it's current condition as the S/C could cause the engine to detonate w/out the extra fuel given by the TRD ECM. It won't leave unless it's fixed or towed to a dealer to get fixed. He assured me their insurance would cover any costs to get it repaired. Quote, originally posted by BlueCrush »WOW! Sorry to hear, Jason. I would first re-wire it. If it still doesn't work then, go for the one on 9thGen. If that's sold, get one of the Unichips for sale on here and get the extra S/C harness for it. Do you know what psi you were boosting at? Because they have 3 different maps depending on where you are already at.That's what they're trying to do, make sure all the wiring is hooked up correctly, and then see what happens. If that doesn't fix it, off to the dealer it goes! I think they're trying to do everything possible to avoid that at this time by trying to repair it in-house, even if it means extra hours on it and keeping it there until it is fixed or given up on. If they can't get the TRD ECM, harness, and clip, I will surely be suggesting the Unichip! It's probably cheaper anyways!Quote, originally posted by AKLGT »as others have already said, there should be no reason for them to be touching your ECU!!!! (removed)?? and again, why are they even starting the car when they do the install?? i'm no expert, but number one thing to do is DISCONNECT THE BATTERY!. so i will agree with a previous post and say it sounds like they cut something and now trying to cta.There's no covering available, they know they ****ed up, they're trying to fix it to cta so it doesn't have to go to a dealer!Quote, originally posted by Mavrik »well granted they have to start your car to move it in and out of the shop... but sure sounds like they
have no idea what they are doing. Best bet would be for them to put down their tools and pay to get it towed to the nearest dealership and have them fix it. That is providing its a stock thing and not something electrical that you have on there thats aftermarket.This is where I'm worried, but the thing is, regardless of what they try to point at, it worked when they drove it in to the bay, now it doesn't, that's all that should natter, as they obviously had to screw something up.
