Make it stop!
nuvibe
Make it stop!
Post by nuvibe »
I have a rattling noise comming from the back of the car (inside) and cant figure where it's comming from and checked everywhere HELP..... nuvibe
WaveAction
Re: Make it stop! (nuvibe)
Post by WaveAction »
when I took home a vibe the other day..i also had a rattling sound in the back...wasnt sure what it was..could be a seat belt hitting the side..or..something in a back compartment or something..or maybe where the spare is
DavidPIL
Post by DavidPIL »
Yeah, have someone sit in the back seat to see if it's coming from there or further back. I noticed my passenger seatbelt buckle sometimes rattles against the door pillar if the belt is twisted a little. Also, in back, could be the tiedown parts in the area of the spare tire, as WaveBlue mentioned. There may be the tiedown straps or maybe the metal slide tiedown pieces in plastic back there. Also, if anything hard plastic is in the 2 rear side compartments, that tends to rattle as well. I put microfiber rags in mine. Lastly, and this was my biggest problem when I first got a license plate surround in the back, it would rattle like crazy when going over the smallest of bumps. I ended up having to tie the plate surround down with wire with rubber bumpers between the surround and the plate. If you have the metal plates, it could very well be that whether you have a license plate surround or not. Make sure there are the rubber bumpers behind the plate as well.Dave
nuvibe
Post by nuvibe »
Neverminde. Rite after I posted this I jetted to Walmart and as I was driving down the freeway I herd pop and bang. I finally found what the ratteling was. It was the top center nut that hold's the shock to spring plate. So I need to see if anyone in the Dago area can help me out to put it back on. Need a spring compressor to do the job. Your help will be greatly be appreciated..... nuvibe
damronjr
Post by damronjr »
Quote, originally posted by nuvibe »I have a rattling noise comming from the back of the car (inside) and cant figure where it's comming from and checked everywhere HELP..... nuvibeI've been noticing the same thing here very recently. I looked everywhere, tried pounding on the panels, but it's still there when my bass hits.
damronjr
Re: (nuvibe)
Post by damronjr »
Quote, originally posted by nuvibe »Neverminde. Rite after I posted this I jetted to Walmart and as I was driving down the freeway I herd pop and bang. I finally found what the ratteling was. It was the top center nut that hold's the shock to spring plate. So I need to see if anyone in the Dago area can help me out to put it back on. Need a spring compressor to do the job. Your help will be greatly be appreciated..... nuvibeYikes, just saw this, better check mine! Time for a SD mini-meet!
nuvibe
Post by nuvibe »
Sorry for delay on the reply. Went to work on saturday and next door is an alignment shop and the guy took a look at it and fix it for $15 buck's and was I happy about that. No more noises..... nuvibe
