Hey you boosting and guage experts... i was wondering about the gauges.1. for a/f gauge do i need wideband or narrow band guage2. oil pressure, anything specific? type?3. volts: pretty basic im assuming... right?Just wanna make sure i get the right ones as im gonna be buying these soon.If you can post some you have or suggest. i want the green glow or a blue glowThanks guys/gals
A narrow band is not very accurate and will be bouncing all over the place. Get a wideband.If you are planning on boosting via S/C, the 3 gauges I would get are: A/F, boost & EGTIf you are planning on boosting via Turbo, I would get: A/F, Boost & Oil PressureIf staying N/A, I would get: A/F, oil pressure, voltsVolts & Oil Pressure are all pretty much the same.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
thanks... BC and cole.I like the cobalt series. they are so Darn expensive though.BC: im satying N/A for now. its just for show/style.I thought wideband would work better. thanks.im planning on a/f, oil pressure, and volts.thanks guys
I don't know about the voltz guage. Unless you have a really good sound system and a couple of batteries to monitor. I would instead use either oil temp, tranny temp, or coolent temp for the third guage.For the A/F, if you have the money then yeah, go for the wide band. But if your just doing it for mostly show, then the regular a/f guage is still pretty cool.
Hmmm? ok... sounds reasonable. i have a basic system setup.so ill look into the oil temp, pressure and a/f thenI just want to easiest to install, ima go cobalt or C2. not sure.thanks lancer
