The Vibe GT uses the 2ZZ-GE 180HP engine. The Vibe uses the 1ZZ-FE 130HP engine.On getting the lift mechanism to kick in at 5000 instead of 6000 everything is possable. I have no idea how you would get it to do it though. At 6000 RPMs the ECU sends a signal to an oil control valve at the end of the camshaft that puts oil pressure behind a lock pin in the rocker arm, sliding the pin under the spring-loaded slipper follower, locking it to the rocker arm and forcing the arm to follow the high-rpm cam profile.Reprograming the ECM you might be able to get it to send the signal earlier but I'm not sure. JET will reprogram the ECM on both Vibe models. They could probably answer this question for you.As for the supercharger your right there isn't one available at this time and I have heard nothing about it coming out. There is a Turbo available for the 1ZZ and the same company (West Covina Toyota) is making one for the 2ZZ also. So forced induction of some kind is going to happen for the Vibe GT.Hotchkis Tuning's sway bars are available for the Vibe and Vibe GT and
http://www.eibach.com has springs that will drop the front 1.8 inches and the rear 2 like you wanted.As far as the ground effects kit that's on the GT-R it's not available from anyone at the moment, to my knowledge. I could be wrong so I will check.Any thing else?
