Ok, it fits wonderfully! no double-sided tape, it clips into the lip in the corners. Toyota Part # PT415-12030, suggested list $65. Much better than the AVS one that 'features' double-sided tape application......yuck
Good deal... Got any pics of it? I've kicked around that idea since I got the Vibe. How much of a difference does it make with the roof fully open? You probably haven't been able to test it considering it is January... Or then again, you could be like me and have the moonroof open quite often when the temp goes above 40 and it isn't raining.
How does a Sunroof Deflector work?Don’t you want the air to blow in?
2004 Vibe AWD Neptune BlueMoon and TunesPower/Security Package1998 Chevy Tahoe"WHAT I HEAR, I FORGET. WHAT I SEE, I REMEMBER. AND WHAT I DO, I UNDERSTAND."
I have one on mine... It defuses the air up and over the sunroof. The OEM sunroof has a small deflector that pops up when you open it but the Toyota one does a better job keeping the air from rushing in. I personally just want the fresh air and sunshine while im driving.
I see the buick rendezvous in the back ground...what all do you guys sell....?We've got GMC,Buick,Pontiac,Isuzu (commercial and passenger)and Hyundai....
Have you guys been busy....?We've seem to have hit a slow spot....past two weeks have beendead....I've got a lot of grumpy techs complaining of no hours...Feast or famine...
Quote, originally posted by tnpartsguy »The one drawback to a sunroof deflector on a Vibe.....it get rock pitted and bug splat stained.Actually I son't have that problem at all. Maybe a few bugs but no rock chips. Once I clean it up, it looks like new
Quote, originally posted by tnpartsguy »Ok, it fits wonderfully! no double-sided tape, it clips into the lip in the corners. Toyota Part # PT415-12030, suggested list $65. Much better than the AVS one that 'features' double-sided tape application......yuck Very nice find! I write down on my purchase list for our Vibe. How hard to install or you have someone do for you? I'm interesting...Thanks
Installation is very easy, it's 2 screws with knurked nuts. you loosely assemble everything, and hook the straps in place, then gently go back and forth from side-to-side slowly tightening. Make sure you put a heavy coat of wax down befroe you install.
