				HELP! starter won't run!
				Posted: Thu Aug 25, 2011 9:20 am
				by bassplayaz06
				so... turn the key, clutch pushed all the way in, hear fuel pump run, but don't hear starter run. replaced the battery cause it's old and needed it anyways, nothing. removed the starter and had it tested at o'reillys, still good. replaced the starter relay, still nothing. checked all the fuses, no blown fuses. checked all the little switches, they're still good.so what i see this leading to is the ignition switch. i went through the diagram for the starter system, checked everything, and this is what it leads to. any clue?!?
				Re: HELP! starter won't run! (bassplayaz06)
				Posted: Thu Aug 25, 2011 11:46 am
				by star_deceiver
				Can you bump start it?  The starter might be stuck in the flywheel or the brushes may be at the end of their life span which a whack with a hammer may prove.  Also try holding the clutch switch with your hand.  It might have moved slightly and the clutch pedal may not be touching it properly.
				Re: HELP! starter won't run! (star_deceiver)
				Posted: Thu Aug 25, 2011 2:55 pm
				by A Psycho Martyr
				Yeah, tapping it verifieid that the starter was bad for me....It worked SOMETIMES, but other times...nothing.Maybe it was a fluke that it tested good?Have someone hold the key in the START position and while you tap on the starter with something (hammer, ratchet, wrench...whatever)...see if it starts
				Re: HELP! starter won't run! (A Psycho Martyr)
				Posted: Fri Aug 26, 2011 4:29 am
				by bassplayaz06
				yeah, that's what it is. i had it out and was lookin at it, then put it back in and this morning it started right up.... gotta go get a new starter now.
				Posted: Fri Aug 26, 2011 12:35 pm
				by bassplayaz06
				got a new starter, hopin that'll fix it.
