hi i was wondering if these rims i saw on Kijiji would fit on my 2003 Pontiac vibe. they are 17inch rims dont know about the bolt pattern. any input would be great. thanks.http://img1.classistatic.com/c....jpegh ... /c....jpeg
Quote, originally posted by moonstonemike »No those wont fit, they are for a 4 bolt but with two sizes drilled in. You need a 5 bolt by 100mm 5X100^What they said. And it looks like he has the same wheels in grey.
K thanks guys, so any input on if these rims will fit, guy said he took them off a pontiac, not sure what make though. there 16inchhttp://img1.classistatic.com/c....jpeg
Those look like they're off a Bonneville, and the Bonnie has a 5-114 bolt pattern, so unfortunately, no. Most Toyota rims as well as Scion rims will fit, though. Many on the board here have OEC TC rims on their Vibes, and they look good. EDIT: Lovemyraffe has TC rims on his Vibe, in his sig.
Bolt pattern is not the only important thing.Offset too, as a wheel can endup too far inside the wheel well or to much outside. Here is a chart http://forums.genvibe.com/zerothread?id=41523Center bore of the wheel too, on Vibe its 54.1mm anything smaller will not even fit and bigger might require a center ring to prevent vibration.
