Would this fit a 2009 standard transmission?
Ghav
Post by Ghav » Thu Apr 01, 2021 3:47 pm
I just bought my car used and the shift boot is a bit worn and tearing in some spots. I'm wondering if there's any indicator that this "universal" boot would fit, or if otherwise any of you have experience replacing the boot and where you bought from.
https://www.amazon.com/dp/B017VE5XFE/re ... CF56CW5D54
I really have no preference as to material, I just want the boot to look fine and fit.
SeattleJeremy
Re: Would this fit a 2009 standard transmission?
Post by SeattleJeremy » Thu Apr 01, 2021 4:00 pm
Make sure to measure the height of the stock boot. I'm not sure 6" of material is enough.
Note: The "installed" picture for the tall shifter is the stock boot on a WRX, and the shorter shifter pictured is the stock boot for a BRZ/FRS.
06 Vibe Base - Mono Platinum - Manual
