What brand are the OEM Oxygen sensors ?
cptnsolo77
Post by cptnsolo77 »
As the topic states. I believe they are Denso...but just wanna double check. Thx !
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
Mark
Re: What brand are the OEM Oxygen sensors ?
Post by Mark »
I pulled one of mine on the 04 to put a spark plug anti-fouler in, to fix the P0420 code. Can't swear to it but I'm fairly sure it was a Denso.
CraftsmanQuad19
Post by CraftsmanQuad19 »
Denso
cptnsolo77
Mark wrote: Tue Feb 16, 2021 7:53 pm I pulled one of mine on the 04 to put a spark plug anti-fouler in, to fix the P0420 code. Can't swear to it but I'm fairly sure it was a Denso.
Thank ! Did you replace the top one ( engine bay ) if so, how difficult was it ?
cptnsolo77 wrote: Tue Feb 16, 2021 8:15 pm
If you're looking to put in a defouler like Mark did, you would do it on the downstream sensor.
The one in the manifold isn't too difficult to reach. You can probably get it from either in the engine bay or from under the car if it's up on ramps.
