How in the hell do you press them in?
Even if you bend the tabs, the metal is in the way plus you have to get pressure on the outside edge...
And just to be clear, the conical shape faces big-side down/inside with the spring that's in the seal facing up/out when pressed in, correct? Because if so, you have 1mm of edge to strike with whatever to seat them and I'm at a loss.
