Quote, originally posted by moseyon »sorry i didn't make myself clear enough. i have an 06 model and i didn't see the instructions in the manual. so if someone can let me know how i would appreciate it. thanks.you can download a copy of the 05 manual from
http://forums.genvibe.com/zerothread?id=1010Quote, originally posted by "2005 Vibe OM Page 2-9" »Programmable AutomaticDoor LocksIf you have an automatic transaxle, your vehicle isequipped with an auto door lock/unlock feature whichenables you to program your power door locks.Your vehicle left the factory programmed to Mode 4.The following is a list of the available programmingoptions:Mode 1: All doors and liftgate lock when the shift leveris moved out of PARK (P) with the ignition on and alldoors and liftgate closed. There is no automaticdoor unlocking.Mode 2: No automatic door locking or unlocking.Mode 3: All doors and liftgate lock when the shift leveris moved out of PARK (P) with the ignition on and alldoors and liftgate closed. All doors and liftgateunlock when the shift lever is moved to PARK (P) withthe ignition on.Mode 4: All doors and liftgate lock when the shift leveris moved out of PARK (P) with the ignition on and alldoors and liftgate closed. All doors and liftgateunlock when the ignition switch is turned from ON toACC or to LOCK.To change the mode you are in, do the following:1. Set the interior lamp control dial to the door position.See Interior Lamps Control on page 3-16.2. Move the shift lever into PARK (P) and close alldoors and liftgate.3. Turn the ignition to ON.4. Within five seconds after the ignition is turned toON, press and hold the power door lock switch inthe lock position for about five seconds.5. The interior lamp will flash to indicate that the modehas been changed. For example, if the lamp flashesonce, the function has been changed to Mode 1.If the battery is disconnected or run down, the mode ischanged to the initial mode which is Mode 4.Quote, originally posted by pacerman »I only use the OD for highway driving, My Maxima is OD default to off, I just feel more comfortable this way, if your doing a lot of city driving it only seems sensible (to me) to have the OD off when you start the car and go.........if you are in the city and never get up to speed for the auto tranny to upshift into the top gear, then it really doesn't matter.
