Post
by joatmon » Fri Jan 08, 2021 4:20 am
The inverter in the first gen is only rated at 100W, which is enough for some things. I needed an inverter for a non-Vibe, bought a 400W one for $30 from Walmart.
However, if you want to reuse a Vibe/Matrix one, here is a PDF of the wiring diagram for the first gen inverter, from a 03 Matrix manual. Don't know what kind of connector you need
029po115.pdf
- 115V inverter wiring diagram
- (19.21 KiB) Downloaded 6 times
