alternator discrepancies
bluneon
Post by bluneon »
i'm searching alternators online and i'm getting differing information about which ones are compatible with a base 2006 with the 1zz 1.8L
some sites say the 210-0395 denso reman works and other sites say it doesn't.
the 210-0393 denso is also giving me the same results, some sites say it fits while others say it doesn't.
which one is correct?
are the alternators in the matrix/corolla the exact same? the original p/n on my current alternator is 27060-0d110 and p/n 27060-0d110-84 is a legit number in the toyota parts catalogue. i'm also finding conflicting information using the toyota part number.
which denso reman should i go with? would it be safe to get one from the toyota dealership? or should i bite the bullet and get one from the GM dealership with vin specific results even though it could take 7-10 days to get here.
thanks, yall.
Re: alternator discrepancies
I can only hope that Denso's own part search program works properly. Here is the link to their site. It shows that the 210-0395 is the proper alternator:
https://www.densoproducts.com/electrical-denso
Live it up: There will be plenty of time to be old when you die.
* '09 Vibe: 1.8 liter *
* '10 Hyundai Elantra Touring *
* '07 Honda Fit Sport *
On Deck: '23 Sportage/'23 Crosstrek Wilderness/'23 Honda CRV
IIRC, the GT and non-GT alternators are interchangeable.
bluneon
Post by bluneon »
i wanted to test the theory that the 27060-0d110 alternators were all the same, regardless of vehicle model.
since the p/n 27060-0d110 shows up on alternators originally installed in corollas and matrixs and vibes i went to the pick and pull. pick and pull alternators are only 20 bucks and considering how easy it is to pull one i might as well try one out.
if it works in the vibe, awesome; then i'd know to order a denso reman from the toyota dealership with a 1 day arrival time.
if it doesn't work, i'd only be out 20 bucks and some of my time and then end up ordering one from GM and wait the 7-10 day arrival time.
i pulled one out of a 2008 1zz corolla with the same matching 27060-0d110 p/n on the sticker.
it's been well over a week and so far it's been working fine.
experiment completed.
