Post
by joatmon » Wed Jun 25, 2008 10:34 pm
No worries. I had to replace mine not long ago. I hated driving around with Recirc on. At one point, I set it to fresh air and when it started thumping, I disconnected the switch to kill the motor, which worked fine until it got hot enough to need to turn the AC on, and since the AC and recirc switches are part of the same switch module, I had to reconnect it to turn the AC on. If it happens again, I'll disconnect the plug at the motor
