one problem with using just a cargo basket is loading and unloading the 160 pound chair
Using an adapter to expand a 1-1/4 hitch to accept a 2 inch hitch adds length to the arm of the hitch, this extension acts as a weight multiplier
- 2Fto125M.jpg (32.02 KiB) Viewed 1038 times
kinda like the difference between picking up a gallon of milk vs. picking it from a distance using a broom handle
I did find two ramped chair carriers that might work, but they are pricey compared to other 2" only carriers, at
https://www.prolineracks.com/wheelchair ... racks.html The description for two of them says " Fits 1.25" & 2" hitch receivers with included adapter sleeve"
I have no way to verify this, but since they use the term "adapter sleeve", it makes me think that the carrier normally fits a 1-1/4 hitch, but if you have a 2" hitch, you can use a sleeve that fits over the carrier to pad it out to 2", something like this pic
- 2Mto125F.jpg (36.13 KiB) Viewed 1038 times
If that's true, then the carriers would plug in fine to a 1-1/4" receiver
and I can't find any 2" receiver hitches for Vibes
There appear to be fancy but even more expensive options, such as
https://www.miamihitches.com/harmar-al5 ... eiver.html
Good luck. Let us know if you ever get it resolved, and welcome to genvibe!
