new gen vibe member with an interstate driving question
Posted: Mon Apr 13, 2015 2:25 pm
by summit
South Dakota is raising the speed limit on the interstate to 80 mph. I am considering buying an 07 vibe with a manual 5-speed transmission. will it drive on the interstate comfortably at 80 to 85 mph?
Re: new gen vibe member with an interstate driving question
Posted: Mon Apr 13, 2015 4:39 pm
by mikevibegt
Hello, i have 03 vibe gt with 6 speed i drove few times from Buffalo NY to Sarasota Florida and it drove really nice,i would reach those speeds on occasion. Now those two cars have completely different gearing and engines.Just to remind you to check for five speed failures here on the Gen VIbe.But I think they solved problems of input shaft bearing by 05 year, if you decide to buy the car I know you will fall in love with it just like many of us here on this website, and you will always have huge trove of information and help here from us guys.
Posted: Mon Apr 13, 2015 5:30 pm
by vibrologist
I would not expect any problems at all driving 85mph with any Vibe. They drive Toyota Corollas on the German Autobahn at even higher speeds. 85mph (about 130km/h) is the "recommended speed" there. I mean the suspension and brakes will handle it easily, the cooling system will be fine. However, you may find it rather noisy as it revs high and the wind blows. It will also raise fuel consumption significantly. My only safety worry would be cross winds.
Posted: Mon Apr 13, 2015 5:38 pm
by gtv237
Mine seems to do fine at those speeds. My only complaint is that the engine rpm stays around 3000 or so. I would like to have a taller cruising gear for better gas mileage but overall it feels very smooth at 80mph. If you have warped rotors or any suspension issues they will be exaggerated the faster you go but any vibe in good shape shouldn't have a problem.
interstate drivability at new 80 MPH speed limit
Posted: Mon Apr 13, 2015 5:39 pm
by Derf
Confirmed automatic Vibe can handle 85 MPH.... But this road was in excellent shape when I traveled, no potholes, gaps, and just a few small hills.
http://www.chron.com/news/houston-texas ... 979397.php
The on/off ramps are 65 mph...
Maybe someone with a manual in Texas can confirm driving characteristics.
But..... double check the driveline. The tires will be making
1113 revolutions per minute! Any shimmy, shake, bump, or tire defect will be magnified. Proper alignment and tire balance is a must. Agree on wind noise anything, over 70 MPH especially into a headwind can get noisy.
Posted: Wed Apr 15, 2015 4:03 am
by vibrologist
Tire balance is critical for high speed driving. It could be a problem finding a shop that does it right. They need to have a top notch machine that spins the tires fast enough. In Germany pretty much every tire shop will get it right, in the US not so much. They get it good enough for the 70 mph speed limits.
At some point I was about ready to take my all seasons to a racing shop.
Posted: Sat Apr 18, 2015 12:59 pm
by summit
Thanks to everyone for the great responses. I checked it out, but have not bought it yet.
Posted: Sat Apr 18, 2015 4:56 pm
by Nasmfell
Probably better to get something with a bigger engine, if you're going to be driving that fast.
Posted: Sat Apr 18, 2015 8:53 pm
by 10vibe
After recently getting back from a 5000 mile trip out west from Ohio, the automatic Vibe with it's teeny little 1.8l engine did just fine at 80 plus miles per hour. Took I40 through Albuquerque and Flagstaff To Las Vegas. On way back, Went back to Flagstaff, then down to Tucson, taking I10 almost to Houston with no problems doing 80mph plus,except for the wish for a couple more gears. Very stable even on worn out oem Goodyear Eagle RSA's....possibly one of my least favorite tires I've had.
Because of a nail in tire near a Walmart the other day, threw out all research on possible replacement tires and went cheap on what they had available in 205/55r/16's, and ended up putting on their special house brand Goodyear Viva 3's all around. I'll hold off on any real opinion for the time being.
Sams Club has an instant $70.00 on Goodyears right now. Tire Discounters looks to have some interesting deals too. Oh well.
Posted: Sun Apr 19, 2015 10:09 am
by hotbug1776
Nasmfell wrote:Probably better to get something with a bigger engine, if you're going to be driving that fast.
Why?
Given that statement, 4cyl and diesel motors must not be sold in Europe.
Your fuel consumption will increase as stated, but, you will still go farther than the minivans and bigger engined cars, as you will still be in the upper 20's to low 30's in MPG's.
at 70MPH, I average about 28-29MPG on the highway (not flat), with all of the go-fast parts.
Posted: Sun Apr 19, 2015 11:08 am
by vibrologist
Why?
I couldn't have said it better myself.
Posted: Sun May 03, 2015 9:01 am
summit wrote:Thanks to everyone for the great responses. I checked it out, but have not bought it yet.
Adding my 2 cents to this topic. Definitely keep the Vibe as a viable vehicle option and DO NOT let a speed "limit" deter your decision. It's just a posted "limit" and not a mandate. In other words, you could still drive comfortably at 70mph in an 80mph zone and you wouldn't be alone. You'll do just fine. Now go out and purchase this Vibe and start enjoying the benefits of Vibe ownership
Posted: Mon May 04, 2015 1:56 pm
by Nasmfell
hotbug1776 wrote:Nasmfell wrote:Probably better to get something with a bigger engine, if you're going to be driving that fast.
Why?
True, but the wind resistance that would have to be overcome going at that speed, The diesel and 4s you mentioned probably are the larger ones 2 liters and up.
Posted: Thu May 07, 2015 2:20 pm
by hotbug1776
Nasmfell wrote:hotbug1776 wrote:Nasmfell wrote:Probably better to get something with a bigger engine, if you're going to be driving that fast.
Why?
The European diesels and the 4cylinder motors are usually set at 2l and below (for tax purposes), and use some form of forced induction to help with the power requirements. As are many of the other country's manufacturers engines, including the US.
Wind resistance? Are you driving a panel van? Aerodynamic design has come a long way since the 80's when you bought your E-350 conversion van. Even newer tractor trailer units are more aerodynamic. We aren't driving U-Hauls, we are driving some of the most fuel efficient vehicles of their time, and they are still quite fuel efficient by today's standards.
Let me just say this, if you are in a car that can't keep up with a dodge caravan on the highway, and be able to pass them if need be, you are in a MiEV or Yugo. The Vibe can run a 85+ MPH all day and never complain, even once.
Posted: Fri May 08, 2015 6:43 pm
by jake75
I do not understand what difference that would make. My 1.8 AT will go 85 mph with no problem though it may struggle a bit going up hill. See my recent post on getting a little under 35 mpg on a 1,245 rt from Ohio to NC.
Posted: Tue May 12, 2015 1:44 am
by lannvouivre
Nasmfell wrote:True, but the wind resistance that would have to be overcome going at that speed, The diesel and 4s you mentioned probably are the larger ones 2 liters and up.
It has no trouble. I do a lot of driving at 85 MPH and have never had any issues. Now, if I need to pass someone doing 60 in a 75, the engine just can't do it too well, especially if the idiot I'm passing gets upset a "wimpy little wagon" is trying to pass.
Posted: Tue May 12, 2015 1:16 pm
by Nasmfell
lannvouivre wrote:Nasmfell wrote:True, but the wind resistance that would have to be overcome going at that speed, The diesel and 4s you mentioned probably are the larger ones 2 liters and up.
That's good to know. Thanks
Posted: Mon Jun 08, 2015 3:56 am
by enfield577
I can confirm that an '09 GT automatic will run all day long on the German Autobahn at 100mph.
At that speed, fuel consumption
IS a problem. Normally I drive around 130-140kph. The Vibe likes that speed. (140kph = 87mph)
I guess the governor is set at 200kph, because I have not been able to get mine to go over 199.
Posted: Sun Jun 14, 2015 4:34 pm
by vibenvy
enfield577 wrote:I can confirm that an '09 GT automatic will run all day long on the German Autobahn at 100mph.
At that speed, fuel consumption IS a problem. Normally I drive around 130-140kph. The Vibe likes that speed. (140kph = 87mph)
Geoff! Glad to see you post! I was just thinking about you and wondering how you and the Vibe are doing across the pond...
Posted: Sun Jun 14, 2015 4:57 pm
by Mark
My son used to compete in karate tournaments in Denver, 100 miles away. Frosty went up and down I-25 at 80 mph a whole bunch of Saturdays, and with the A/C on at least half of the trips. Still got ~34mpg avg per tank.
Posted: Sun Jun 14, 2015 6:25 pm
by vibrologist
Mensch, Mann! Your vibe looks fantastic with the Alps for a back drop. Which mountain are we looking at?
Posted: Tue Jun 16, 2015 6:54 am
by bull77
+1 - the engine noise from my 06 would drive me crazy for a prolonged drive over 120km/h.
Posted: Tue Jun 16, 2015 6:45 pm
by Nasmfell
bull77 wrote:Nasmfell wrote:Probably better to get something with a bigger engine, if you're going to be driving that fast.
I would not doubt it
Posted: Mon Dec 21, 2015 8:07 am
by enfield577
vibrologist wrote:enfield577 wrote:I can confirm that an '09 GT automatic will run all day long on the German Autobahn at 100mph.
Sorry, in my Vibe-isolated area, I don't log in here much anymore, so I just now read this.
That is the Untersberg mountain between Berchtesgaden, Germany and Salzburg, Austria. The view is pretty much the same as the final scene in
The Sound of Music (that scene was filmed 3-4km on up this road from here).
Posted: Mon Dec 21, 2015 4:28 pm
by thebarber
I drive 130miles round trip to work at 75-80mph in my 03GT. It happily hums along at 3500rpm. Getting 28-30mpg
I'd like to pick up a cruze eco 6M though.
