hotbug1776 wrote:yes rear diff leak, listen for any noises, replace the gasket and refill the rear diff oil ASAP if it's quiet still. gasket is/was prone to leakage, not sure if there were design changes to eliminate this.
doppelganger wrote:Hi,
New member here. Not a Vibe owner (yet), but I'm considering buying one.
There is a 2004 Vibe with AWD that is going to auctioned off at an estate sale next month (http://smauctioneers.com/html/0913.html" onclick="window.open(this.href);return false;). I went to look at it recently, and the body and interior seem to be in great shape. The engine bay is kind of dirty, but it sounded fine. (I have a Toyota Celica with the same 1ZZ-FE engine.) Fluids looked clean from what I could tell (may have been changed recently). Car has 126,000 miles, and I think most components are probably still original.
However, there is a leak of some sort from what I think is the rear differential. (I took a picture from under the back bumper, but it's not a very good view.)
I'm not sure if it's just a seal, or if it's evidence of needing to replace additional components. The auctioneers allow visual inspections, but not road tests, so I wouldn't have a chance to drive it to listen for any unusual sounds while driving.
That leads me to my two questions:
1) Can you confirm based on the attached photo if that appears to be a leaking rear differential?
2) How big of a concern is this? Should I pass on this car, or just lower my bid assuming that I may have to repair/replace the rear differential?
Thanks for your input!
Passing on it simply because they won't let him test drive is a bit unfair given the it's an auction. No harm in him deciding what's it's worth to him given the possibility of simply having to change a gasket. Hard to know if it's worth it to the rest of us given there's no price.lannvouivre wrote:Sounds a bit too risky. If they won't let you drive it, I'd say they're hiding a major problem. The most I'd bid on it is like $500.
ImUrOBGYN wrote:Passing on it simply because they won't let him test drive is a bit unfair given the it's an auction. No harm in him deciding what's it's worth to him given the possibility of simply having to change a gasket. Hard to know if it's worth it to the rest of us given there's no price.lannvouivre wrote:Sounds a bit too risky. If they won't let you drive it, I'd say they're hiding a major problem. The most I'd bid on it is like $500.
You can always slyly spread your concern to other prospective bidders about the rear diff.![]()
To the OP, once you've decided on a max bid, stick to it.
Quite possibly. I'm not there to actually see it, however, I'm very familiar with auto auctions and do all my own mechanical work. Now, if you're asking me whether I'd bid 10k or something, then no.Nasmfell wrote:ImUrOBGYN wrote:Passing on it simply because they won't let him test drive is a bit unfair given the it's an auction. No harm in him deciding what's it's worth to him given the possibility of simply having to change a gasket. Hard to know if it's worth it to the rest of us given there's no price.lannvouivre wrote:Sounds a bit too risky. If they won't let you drive it, I'd say they're hiding a major problem. The most I'd bid on it is like $500.
Would you take a risk and bid on it, if you were in that situation?
