07 Vibe No Start only Crank
AstralOddity
Post by AstralOddity »
After replacing the fuel injectors it was running great for a few days I went to a friend's house, and on the way home I stopped at the store and Gray got back to the car I wouldn't start I have since replaced the starter, ignition switch, in for some reason the clip of wires that clips to the solenoid on the starter that tells the solenoid to engage wasn't getting power so I'd bypass that with a push button start and I still have the key but you're going to turn the key and then press the button to turn it over and let off the key it won't start... What am i missing?
