05(base) Vibe
jamesmetairie
05(base) Vibe
Post by jamesmetairie »
about 135,000 miles on it.
The drivers side , inner c/v axle boot is busted open.
So far its making no noise or driving issues.
Am I correct =- it should start clicking on turns and roaring at speed ?
Bookworm
Re: 05(base) Vibe
Post by Bookworm »
The boot is split, or the axle is open?
If just the boot, you can probably get away with having a mechanic repack it and put on a 'boot kit'.
jamesmetairie
Re: 05(base) Vibe
thanks bookworm.
Bookworm
Re: 05(base) Vibe
Post by Bookworm »
I had CV joints go in previous cars. grinding on the turns is usually the very first sign. It's not something to take lightly, as your wheel _can_ separate if ignored long enough.
