Hi Folks!
My question has to do with my 2005 Pontiac Vibe.
Backstory: I had a usb cable that was stuck between the steering wheel and the column. It was quite hard to get out, and I had to pull it quite hard to get it out. After I got it out, my horn and cruise control didn't work, and the airbag light came on in the dash. This leads me to believe that it's the clockspring.
I unhooked the battery (let it sit a good half hour), got the Torx screws out of the steering wheel, and loosened the horn button. Now, however, the horn button seems to be hooked somewhere and I cannot pull it off.
Does anyone know if the horn button is indeed hooked somewhere, or is there a tab that needs to be pushed to get it off? I don't want to just go and start pulling things without knowing what the outcome could be.
(My overall intention is to see if the clockspring merely needs to be plugged in, or replaced entirely. The clockspring is readily available, but if it's only a matter of reconnecting it somewhere, that's what I'm going to do.)
Thanks for any help anyone can give! I like to tinker with things, and this looks like an opportunity to
