WestC4: I think this is normal. When the engine is cold the mixture is rich and the idle is high. This is necessary because the fuel condenses when it hits the cold surfaces in the cylinders. By keeping it rich there remains enough atomized fuel in the air to ignite. That also means that a lot of unburned fuel goes through the tailpipe. Now, you say, but there is a catalytic converter that should burn off those extra hydrocarbons. Well, I say, you are correct but the catalytic converter is still too cold to do its job.WestC4 wrote:checked under the seat. cap and lines are good. im wondering if this is just due to the car idling high. ive been watching and it seems I only notice this when I start the car up for the first time in the morning and when I leave work. I know that until the engine warms up the car idles closer to 2000 rpm. maybe im just a little paranoid, I haven't been the main driver of this car until recently. it was my wifes dd, but now she has a newer ride and the vibe has become my work dd.
sorry for the rambling, but just looking for some advice and/or wisdom, thanks
WestC4
did you mean: "doesn't hurt?"Salsa Guy wrote:^^X2 but doesn't help to check out the fuel pump and maybe inspect the exhaust.
Yes I did and it's been corrected. THANKS!vibrologist wrote:did you mean: "doesn't hurt?"Salsa Guy wrote:^^X2 but doesn't help to check out the fuel pump and maybe inspect the exhaust.
reuseaway wrote:I can definitely smell something when I'm idling. I found that if you don't blow in outside air that you can't smell it. Can turn on outside air (vs recirculate) when you are moving with no problem.
Both me and my mechanic looked for obvious exhaust leaks and couldn't find anything that sounded like on.
Magnaflow 99205HM is a direct fit for the 03-08 FWD Vibes. $100 part, $50 weld job. Don't waste stupid money on an OEM one.
It's been 4 years and nearly 50k miles on my Magnaflow converter. Perfect fit for the lower converter. Odds of the upper converter being an issue is pretty slim. Many others on the FB have ran the exact same converter for much longer than I have with great success. It's a much better alternative than shelling out $1k on a converter on a 16 year old car with 280k miles.Bookworm wrote: ↑Mon Jun 03, 2019 9:48 am I used these folks.
https://www.discountconverter.com/direc ... /index.cfm
I wouldn't touch a $100 catalytic converter if you paid me. They tend to be low on the catalyst, for one thing.
They also only have one cat, and the Vibes have two.
1k? I paid around 500 for an exact fit, no cutting/welding needed, with two oxygen sensors, and had it installed. (not installed by them, but as part of that price). It's still on the car, 80k+ miles later, with no issues whatsoever.zbyers wrote: ↑Mon Jun 03, 2019 11:49 amIt's been 4 years and nearly 50k miles on my Magnaflow converter. Perfect fit for the lower converter. Odds of the upper converter being an issue is pretty slim. Many others on the FB have ran the exact same converter for much longer than I have with great success. It's a much better alternative than shelling out $1k on a converter on a 16 year old car with 280k miles.Bookworm wrote: ↑Mon Jun 03, 2019 9:48 am I used these folks.
