Sonders wrote:
Mine has basic single disc cd player hu but has speakers with front door post tweeters if that does matter.
Does it have a chime module or anything?
There is no chime module. Some cars use the radio system to put out beeps and alarms like door ajar, seatbelt, etc. The Vibe doesn't do that. it uses a simple beeper on the back of the gauge cluster. So there's no radio chiming to worry about.
If you have tweeters in the door posts, (and it came from the factory that way) then you would also have a sunroof. Vibes had a package called Moon & Tunes, which gave you the sunroof, the tweeters, and also an audio power amplifier under the front passenger seat. This power amplifier can be an issue with a a replacement head unit. A number of people who have installed an aftermarket head unit to feed that amplifier had a problem with loud clicks coupling through the system, which they got around by putting some sort of level converter between the head unit and the amp. I still have an OEM radio in my Moon&Tunes vibe, so have never had to deal with it first hand, and don't know what specs to put on this level converter thing, just reporting that a lot of folks in your situation seem to have needed one.
