It's pretty straightforward once you have the wheels up.
Only 2 tips I can offer are:
-- Release the tension on the link with a floorjack under the knuckle
-- Make sure you have a proper fitting socket beforehand to hold the link stud in place when you remove the bolts.
Don't know the size or whether it's a torx/hex socket. Without this the stud will just spin in place.
