HVAC Blower Fan Removal
striker1211
Post by striker1211 »
This took me 5 minutes with taking pictures with the proper tools:
Phillips Screwdriver
10mm Socket
7/32 Socket (5.5mm)
MAYBE a flathead for plastic pcm pins.
[edit] Just noticed there is already a tutorial for this... oh well.
Unscrew phillips screw from glove box support arm.
Remove two plastic retaining pins. It was easier for me to just pull between the PCM and the plastic to get the pins out a little and then grab them.
Remove 2 10mm (or phillips) bolts holding the PCM mounting bracket.
Swing itout of the way taking care not to rip any wires out of the harness. You do not have to disconnect anything from here.
Disconnect the wiring harness from the motor
Disconnect the rubber tube at the end closest to the firewall (engine)
Remove 3 7/32 screws. 5.5mm in metric. Careful here because the motor is kind of heavy and it will be right on your face.
Bonus: While you are in there change your air filter like I did :)
Motor outside of cage.
My Vehicle: 2008 Vibe Moon & Tunes 1.8L ATX
Wolfman213
Re: HVAC Blower Fan Removal
Post by Wolfman213 »
Good pics and good write-up! It was definitely a simple job. It took me about 15 minutes though trying to find the right socket though lol.
Persephone
Post by Persephone »
Thanks so much for this. It made my job a whole lot easier.
My lovely Gambit.
